Author [NL] [FR] [ES] [DE] [SE] [IT] Manifold studs - aftermarket  (Read 275 times)
  • Offline Nharri103
    • Tiger Cub  ‐    4
    Offline Nharri103
    on: Jun 21, 2022, 12.37 pm
    Hey all!
    I’ve just been through the joyous task of taking the headers off my 2011 xc. It was not easy. Luckily none of the studs snapped in the head although some did snap at the bolt.
    I want to get some better studs for the new headers, but triumph only sell mild steel studs. Does anyone have any recommendations for alternatives that are a bit more rob(r)ust?? And easier to work with over time?
  • Offline awjdthumper   gb
    • Tiger Master  ‐    812
    Offline awjdthumper
    • Bike/Model: Tiger 800 XCA
    Re: Manifold studs - aftermarket
    Reply #1 on: Jun 21, 2022, 01.46 pm
  • Offline Nharri103
    • Tiger Cub  ‐    4
    • #2
    Offline Nharri103
    Reply #2 on: Jun 21, 2022, 02.08 pm
    Perfect, thanks for that! I gave them a call to double check, and put the order in! The guy was really helpful actually, I'll be going back there again (not for studs hopefully).
  • Online Paulhere   gb
    • Tiger Jedi  ‐    2275
      #3
    Online Paulhere
    • Bike/Model: Tiger 800 XRx
    Reply #3 on: Jun 22, 2022, 09.25 am
    If an SS stud snapped, it'd be a bugga to drill out.
    In our yoof we'd fit brass nuts, whatever happened to that idea, some cars came with them. Easy to cut off without damaging the studs.
  • Offline StewartG   gb
    • Tiger Pro  ‐    149
      #4
    Offline StewartG
    • Bike/Model: S/Triple 765RS
    Reply #4 on: Jun 22, 2022, 10.02 am
    With ss make sure you put copper grease on thr threads before putting them in the head. if you use stainless nuts also put copper grease on as well. I have had no trouble using this tecnique
    Stealth Tiger, Black is Best
      #5
    Offline awjdthumper
    Reply #5 on: Jun 22, 2022, 01.42 pm
    As said, you have to be careful fitting SS nuts on to SS threads to prevent galling (cold welding). Copper slip usually prevents it or copper nuts which is what I've got fitted on my other bike with SS exhaust studs.
