Home
Search
Member Map
Photos Gallery
Login
Register
VIEW MEMBERS
ERROR LOG
MAINTAIN DATABASE
ATTACH & AVATARS
MANAGE THEMES
BLOCK LIST
Login/Register
RECENT POSTS
UNREAD TOPICS
UNREAD REPLIES
BOOK MARKS
PHOTOS GALLERY
HELP PAGES
ACCOUNT
SETTINGS
FORUM
PROFILE
MY POSTS
MESSAGES
NEW = 0
LOGOUT
Recent Posts
Please
login
or
register
LOGIN
JOIN
Triumph Tiger 800 Forum
Tiger 800 XC idling problems
16 Aug 22, 22:32 pm
1
2
3
4
Go Down
Author
Tiger 800 XC idling problems (Read 1651 times)
staelens
Tiger Member ‐
18
Topic Author
staelens
Tiger Member
Topic Author
Bike/Model: Tiger 800 XC
Country:
on:
Jul 01, 2022, 07.57 pm
Hi all,
First of all; happy to be a member here. Learned a lot already before registering. I recently bought a Tiger 800 XC from 2012 with 19000kms on the clock. It has been used for proper offroading in Africa, so the kilometers on it are pretty heavy ones :)
I instantly started having problems with starting/idle; the bike stalled easily when idleing and it sometimes was hard to start it. Did some research and found a TON of info/problems about the stepper motor, so decided to clean it. When I was at it i also replaced the spark plugs and the airfilter.
I cleaned the stepper motor and surroundings with WD40 and then lubed it with a dry lube.
So, after doing so (cleaning the stepper motor, replacing spark plugs and airfilter), reassembled to whole bike and it seemed to idle better; steady around 1100rpm. I started it for a couple of times and it always started fine so I decided to take it for a test drive. I just rode it and now it's even worse than before, only after a couple of 100 meters i can't even keep it in idle. As soon as I pull the clutch the bike stalls, very dangerous actually. Starting and keeping it idleing is just impossible now, it seems to flutter between 600 and 800 rpm, not steady at all and stalls every time. What went wrong here? Any ideas? It rides perfectly fine if i keep the revs up.
Last Edit: Jul 01, 2022, 08.00 pm by staelens
chuckxc
Tiger Jedi ‐
1207
chuckxc
Tiger Jedi
Bike/Model: 12XC, 18XCX
Country:
Re: Tiger 800 XC idling problems
Reply #1 on:
Jul 01, 2022, 10.30 pm
From what you wrote it appears you have spark and air flow renewed. The next simple question would be fuel flow.
Is your fuel tank clear of water/dirt?
Are you certain you have installed the idle control stepper motor correctly?
Are you sure you have reconnected all the MAP hoses, especially the one attached to the manifold air pressure sensor?
awjdthumper
Tiger Master ‐
899
#2
awjdthumper
Tiger Master
Bike/Model: Tiger 800 XCA
Country:
Reply #2 on:
Jul 02, 2022, 06.03 am
It sounds like classic stepper motor issues many of which are caused by accumulated muck around the mechanism - the fact that this bike had been subject to serious off-roading points in this direction. The link below shows one particular aspect of this problem and might be worth checking this hasn't happened in this case:
https://www.tiger800rtw.com/tiger-800-stepper-motor-problem/#:~:text=The%20Tiger%20800%20stepper%20motor,motor%20clean%20during%20regular%20servicing
staelens
Tiger Member ‐
18
Topic Author
#3
staelens
Tiger Member
Topic Author
Country:
Reply #3 on:
Jul 02, 2022, 06.13 am
Originally Posted by
chuckxc
I’m going through the same process again today and reconnecting everything. Could it be that the bolt on top of the stepper motor it too tight/not tight enough? In my memory all the hoses were reconnected correctly but I might have done something wrong, i’ll report back here. Wich one is the MAP hose that connects to the manifold air pressure sensor?
Edit; after some research it seems that some people have a problem with the hoses disconnecting while driving, making the bike unable to stall. It sounds like that gives my problem, so i’m guessing one of the hoses came off during my test drive. If thats the case, any tips on reattaching it more securely?
Last Edit: Jul 02, 2022, 06.20 am by staelens
awjdthumper
Tiger Master ‐
899
#4
awjdthumper
Tiger Master
Country:
Reply #4 on:
Jul 02, 2022, 06.29 am
I seem to remember my Tiger would not start with the MAP hose removed. The MAP sensor is front right on the air box and it just needs to be checked that the vacuum hose is in place.
staelens
Tiger Member ‐
18
Topic Author
#5
staelens
Tiger Member
Topic Author
Country:
Reply #5 on:
Jul 02, 2022, 06.40 am
awjdthumper
Thanks a lot, I do remember reconnecting it, but maybe it came back off when messing around with the rubber air inlet on the airbox or something... A coffee and back to it, thanks already!
staelens
Tiger Member ‐
18
Topic Author
#6
staelens
Tiger Member
Topic Author
Country:
Reply #6 on:
Jul 02, 2022, 07.48 am
I just removed the tank and airbox again and checked; all hoses and connectors were connected properly and snug.
I did adjust the stepper motor bolt a little bit because it was too close to the bracket.
When I give the bike power to check what the stepper motor is doing, I can hear it click very softly. The clicking comes from the stepper motor, I can feel it vibrate slightly with my finger. After putting the bike to off again, I want for the stepper motor to do it's faxy-thing and when it does it barely moves, not more than a couple of mm's. I don't think this is right? Maybe stepper motor gone?
awjdthumper
Tiger Master ‐
899
#7
awjdthumper
Tiger Master
Country:
Reply #7 on:
Jul 02, 2022, 08.04 am
I have no direct experience with this stepper motor set up (my Tiger is Gen 2) but I would be tempted to disconnect the motor and then to see what it does and to also examine the actuator mechanism to convince yourself that it operates smoothly. The stepper motor can be tested using TuneECU or possibly using TigrTool. I would have thought the motor either works or doesn't work and the problem is more likely with the rest of the actuator mechanism
staelens
Tiger Member ‐
18
Topic Author
#8
staelens
Tiger Member
Topic Author
Country:
Reply #8 on:
Jul 02, 2022, 08.33 am
Well, update; It seemed that i DID make a mistake in reconnecting the stepper motor
The plastic thingy was not horizontally positioned. I changed that and reassembled, but it still doesn't want to idle. It idled at first start at around 800rpm (on a cold bike) and next startups just didn't want to idle. Where to go next? Get me an OBD2-USB cable and try with tuneECU?
staelens
Tiger Member ‐
18
Topic Author
#9
staelens
Tiger Member
Topic Author
Country:
Reply #9 on:
Jul 02, 2022, 10.27 am
Well, argh. Connected everything again after another clean (yet again), but no solution. Also; the dash indicated there's no fuel at all (not even 1 bar), but there is at least 5L in the tank... Pretty frustrating to feel like you made it worse than before -_-
1
2
3
4
Go Up
New
New Members
coddy
Today
at 09:10 pm
First Tiger 800!
New Members
coddy
Today
at 09:08 pm
no power to auxiliary sockets
ped
Today
at 08:09 pm
Tiger 900 items for sale
For Sale
Dizzy
Today
at 07:44 pm
Bad oil
Paulhere
Today
at 06:17 pm
TEKMOUNT for GPS
Sat Navs, Intercoms, Cameras, and other tech gadgets
Derchef1962
Today
at 04:44 pm
What do y'all use for tank bags?
Derchef1962
Today
at 04:37 pm
How To Use TigerTool V3.3 Service Utility Software
"How To" Technical Articles
eskalextric
Today
at 11:37 am
Buy a rear sprocket from...?
Ben_snapper
Today
at 11:22 am
*** SOLD *** Tiger 800 - hand guard and brake lever
For Sale
grunty-motor
Today
at 09:14 am
