Home
Search
Member Map
Photos Gallery
Login
Register
VIEW MEMBERS
ERROR LOG
MAINTAIN DATABASE
ATTACH & AVATARS
MANAGE THEMES
BLOCK LIST
Login/Register
RECENT POSTS
UNREAD TOPICS
UNREAD REPLIES
BOOK MARKS
PHOTOS GALLERY
HELP PAGES
ACCOUNT
SETTINGS
FORUM
PROFILE
MY POSTS
MESSAGES
NEW = 0
LOGOUT
Recent Posts
Please
login
or
register
LOGIN
JOIN
Triumph Tiger 800 Forum
Brakes and ABS
ABS issues
15 Aug 22, 16:21 pm
1
3
4
5
6
Go Down
Author
ABS issues (Read 1827 times)
GCB903XRX
Tiger Member ‐
20
Topic Author
#40
GCB903XRX
Tiger Member
Topic Author
Bike/Model: Tiger 800 XRX
Country:
Re: ABS issues
Reply #40 on:
Aug 01, 2022, 02.45 pm
Originally Posted by
awjdthumper
If I understand you correctly, you bled the ABS pump yesterday just to see if it was the cause of the present problems? I assume it made no difference?
If the ABS has activated then this might imply that the problem is missing pulses from the front sensor, perhaps fooling the ABS ECU into thinking the front wheel has stopped rotating or is starting to slide - in principle, if the ECU detects this, it will pulse the brake pressure via the ABS pump.
However, if the ABS has not operated then the problem may be more fundamental and have nothing to do with the wheel sensors. If this is the case then I think you are going to need access to some clever diagnostics to work out what the problem is which may require a Triumph dealer!
Correct. ABS bleed made no difference. After clearing the codes the bike runs with no faults. At the least touch of the front brakes the ABS then operates and triggers all the errors . I am very tempted to replace the ABS ring at this point.
awjdthumper
Tiger Master ‐
898
#41
awjdthumper
Tiger Master
Bike/Model: Tiger 800 XCA
Country:
Re: ABS issues
Reply #41 on:
Aug 01, 2022, 03.13 pm
How do you know the ABS is operating when you pull the brake lever? Can you, for example, hear the ABS pump pulsing or vibrating?
GCB903XRX
Tiger Member ‐
20
Topic Author
#42
GCB903XRX
Tiger Member
Topic Author
Country:
Re: ABS issues
Reply #42 on:
Aug 01, 2022, 03.24 pm
awjdthumper
The brake lever pulses.
awjdthumper
Tiger Master ‐
898
#43
awjdthumper
Tiger Master
Country:
Re: ABS issues
Reply #43 on:
Aug 02, 2022, 06.53 am
At face value, the problem seems to be with the pulse stream from the speed sensor which is either confusing the ABS ECU or making it believe there are missing pulses. You have changed the speed sensor which appears to have had no real effect ruling the sensor itself out as the cause of the problems. The pulse ring is made of steel and designed to perturb the magnetic field inside the sensor and, even if magnetised in some way, I doubt if this would affect the way the sensor works.
Ideally, the sensor output at the connector should be tested using a waveform scanner - although it seems unlikely there is a problem at this point, without the necessary test equipment, there is no way of verifying this.
Assuming the problem is not at the sensor output, this probably leaves only two possibilities. The first is a wiring fault between the sensor connector and the ABS ECU. Assuming the wiring harness itself has not been damaged then the only possibility would be a poor connection at the ABS ECU. Therefore, removing the ABS ECU connector and checking the pins for corrosion would be worthwhile.
The only other possibility to explain the problems is a fault inside the ABS ECU itself. Unfortunately, without the necessary test equipment and diagnostics software, it would be very difficult to verify this sort of fault which could only be done (I assume) in a Triumph workshop. The alternative might be to take the risk and replace the ECU.
GCB903XRX
Tiger Member ‐
20
Topic Author
#44
GCB903XRX
Tiger Member
Topic Author
Country:
Re: ABS issues
Reply #44 on:
Aug 03, 2022, 10.41 am
awjdthumper
Thanks. Now to locate the ABS ecu
T800XC
Premier Member
Tiger Jedi ‐
2725
#45
T800XC
Premier Member
Tiger Jedi
Bike/Model: Tiger 1200 XRT
Country:
Re: ABS issues
Reply #45 on:
Aug 03, 2022, 11.13 am
GCB903XRX
It's attached directly to the ABS modulator.
awjdthumper
Tiger Master ‐
898
#46
awjdthumper
Tiger Master
Country:
Re: ABS issues
Reply #46 on:
Aug 03, 2022, 07.34 pm
This is what the complete assembly looks like:
GCB903XRX
Tiger Member ‐
20
Topic Author
#47
GCB903XRX
Tiger Member
Topic Author
Country:
Re: ABS issues
Reply #47 on:
Aug 08, 2022, 10.14 am
So yesterday I did another experiment. I reset the error codes and went for a slow spin without using the brakes at all. After about half a kilometer the error lights still came on and ABS and TC were disabled. I've been busy but I should find some time this weekend to take her apart and put some contact cleaner on the connections. After that I imagine I'm up for a replacement unit.
awjdthumper
Tiger Master ‐
898
#48
awjdthumper
Tiger Master
Country:
Re: ABS issues
Reply #48 on:
Aug 08, 2022, 11.37 am
You said previously that when you hit the front brake, the ABS would operate because you could feel the pulsing through the handlebar lever. Presumably, this was followed by the error light coming on?
It sounds as though the error light came on yesterday without you first operating the brakes? Is this correct?
Having the ABS operate when it shouldn't is definitely something that needs to be sorted. However, if the ABS simply gets disabled then that is a problem that is easier to live with
GCB903XRX
Tiger Member ‐
20
Topic Author
#49
GCB903XRX
Tiger Member
Topic Author
Country:
Re: ABS issues
Reply #49 on:
Aug 08, 2022, 12.07 pm
awjdthumper
Correct on the first two points. The ABS and TC simply get disabled and considering that my previous bike had none and I'm no dare devil rider I could live with that for a while although I did upgrade for the added safety. Price for a new ABS unit is close to €1500. I also found a used unit for less than €100
1
3
4
5
6
Go Up
Bad oil
K1W1
Today
at 11:43 am
900 GT Pro TES System fault
awjdthumper
Today
at 08:03 am
Scruffy panniers
Wellingtonbo
Today
at 04:38 am
Tiger 800 - hand guard and brake lever
For Sale
grunty-motor
Yesterday
at 08:45 pm
What do y'all use for tank bags?
coach
Yesterday
at 07:55 pm
Tiger 900 - Garmin Zumo XT
mcinlb
Yesterday
at 07:48 pm
2013 tiger 800 arrow exhaust / end can
For Sale
deefer45
Yesterday
at 07:10 pm
Tiger 800 Wilbers 641rear shock full adjustable comp and rebound, remote preload
For Sale
deefer45
Yesterday
at 06:45 pm
Baby Triumph Update?
On Two Wheels
Stevie.P
Yesterday
at 06:32 pm
TEKMOUNT for GPS
Sat Navs, Intercoms, Cameras, and other tech gadgets
RideTheTiger
Yesterday
at 05:32 pm
