Author [NL] [FR] [ES] [DE] [SE] [IT] Does anyone know which panniers fit these racks?  (Read 1093 times)
  • Offline Keyoke_1   gb
    • Tiger Member  ‐    21
    Offline Keyoke_1
    • Bike/Model: Triumph Tiger 800XC
    on: Nov 12, 2023, 12.23 am
    First of all, apologies if this is a bit of a daft question.. Have bought the bike today (not yet delivered - that happens in about a week), and whilst there is a top-box fitted already, and the pannier racks - there are no panniers. As I am planning a few rallies etc over the next couple of years these would be quite useful...
    I *think* these are the OEM Trekker pannier racks (bike is a 2014 800XC), but there seems to be quite a lot of options available - and none of the pics I can find quite match the shape of these ones. Any help/links appreciated.
  • Offline K1W1   au
    • Tiger Jedi  ‐    5914
    • Up in the hills
    • Bike/Model: XRX
    • Country: au
    Re: Does anyone know which panniers fit these racks?
    Reply #1 on: Nov 12, 2023, 12.54 am
    They are Givi racks. Givi or Givi compatible panniers will fit. If you want to use soft panniers or panniers with a backing plate just remove the lugs.
  • Offline Londonglide   gb
    • Tiger Master  ‐    391
      #2
    Offline Londonglide
    • Bike/Model: XC
    Reply #2 on: Nov 12, 2023, 10.13 am
    Small point to add. They are for Monokey systems. I'm not sure they fit Monolock ones.
    They will also fit the Kappa branded panniers, which are Givi's but rebranded.
    From some website
    "Monokey cases are interchangeable and can be used as top or side cases. Monolock cases are designed as top cases only, they cannot be used as side cases. Monolock cases come with their own universal mounting hardware/plate which is not interchangeable with the Monokey series mounts"
    • Tiger Member  ‐    21
    • #3
    Offline Keyoke_1
    Reply #3 on: Nov 12, 2023, 07.57 pm
    Brilliant, thank you both - will see what I can find (once I've sorted the rest of the stuff I need...!)
    K
  • Offline Paulhere   gb
    • Tiger Jedi  ‐    2477
      #4
    • Bike/Model: Tiger 800 XRx
    Reply #4 on: Nov 14, 2023, 09.48 am
    Those Givi racks will also fit others, eg SW Motech Trax  panniers, needs the alternative fitting kit, Squaredeals sell that approx. 20.
    • Tiger Member  ‐    21
    • #5
    Offline Keyoke_1
    Reply #5 on: Nov 15, 2023, 07.19 pm
    Cheers for the info - gives me a couple of others to check out..!
    K
