Author [NL] [FR] [ES] [DE] [SE] [IT] R&g heated 22mm grips  (Read 9735 times)
  • Offline Rustyblack
    • Tiger Member  ‐    78
    Offline Rustyblack
    • Old but not too bold.
    • Bike/Model: Tiger XRx 800
    on: Nov 29, 2023, 05.05 pm
    My rh grip is not heating, checked it is getting power to it, and earth is OK so presume element has gone.
    Anyone tried replacing them with the r&g 22mm size grips?, I know the wiring would probably not run through the bars, but not to worried.
    Just wanted to know if they are an easy fit to the bars, as I can graft into the OE switch block wiring.
    Or any other make suggestions/recommendations please.
    Always consider that your alter ego may be coming the other way on the road you are on. 💥💀
    • Tiger Member  ‐    78
    • #1
    Offline Rustyblack
    Re: R&g heated 22mm grips
    Reply #1 on: Jan 29, 2024, 07.32 pm
    All fitted and much better now. Toasty even in -7c a couple of weeks ago.
    I did try using the Triumph controller but the heat was not building up, so fitted the suppliers one and all good, same power draw and same power supply so maybe the original controller is just too limiting.
    Last Edit: Jan 29, 2024, 07.35 pm by Rustyblack
