Author [NL] [FR] [ES] [DE] [SE] [IT] ECU damaged  (Read 629 times)
  • Offline Dixie   england
    • Tiger Cub  ‐    6
    Offline Dixie
    • Bike/Model: Tiger 800xc
    • Country: england
    ECU damaged
    on: Feb 07, 2024, 12.53 pm
    Hello all Newby to here
    I have a 2012 tiger 800xc with a fried ECU and what looks like damaged clocks/ speedo, rev needle is pointing at 5
    Reading from a post back in 2021 from mega chops my bike has the exact same problem
    Any advice on what parts will need replacing & where is best to source these, I'm in  Yorkshire UK
    My understanding is ECU ignition with key and immobiliser ring Reg rec battery and clocks will need to be replaced
    Last Edit: Feb 07, 2024, 12.58 pm by Dixie
  • Online D6864   gb
    • Tiger Master  ‐    433
      #1
    Online D6864
    • Bike/Model: White XC
    Re: ECU damaged
    Reply #1 on: Feb 07, 2024, 02.08 pm
    Reg/rec, battery and ECU probably, clocks might be repairable. Key, ignition switch and immobiliser ring probably reusable. Replacement ECU will need to be paired with your immobiliser by a Triumph dealer.
    • Tiger Cub  ‐    6
    • #2
    Offline Dixie
    • Country: england
    Re: ECU damaged
    Reply #2 on: Feb 07, 2024, 02.12 pm
    Thanks for the info
    I will call my local triumph dealer
    Would you know where I could get the clocks repaired
