Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
February 24, 2021, 07:56:01 PM
Home
Forum
Search
Members Map
Photos Gallery
Login
Register
Triumph Tiger 800 Forum
Scotoiler
Print
Pages:
1
2
3
4
5
Go Down
Author
Topic: Scotoiler (Read 9622 times)
GringoRojo
Dancing on Ice Champion 2010
Tiger Jedi
a Doonhamer in exile
Bike: TigerXC ABS
Re: Scotoiler
Reply #10 on:
December 04, 2010, 09:01:00 PM »
sounds like you maybe overfilled it then. hot was hot?
Logged
Countries I've ridden: Scotland, England, Wales, Northern Ireland, Ireland, France, Switzerland, Spain, Andorra, Denmark, Sweden, Finland, Norway, Canada (hired bike).
Memorable places: Applecross, Barra, Calanish, Lascaux, Pyrenees, Connemara, Tofino, Lillooet, Sulphur Mountain, Nordkapp, Dalsnibba, Borgund stavkirke.
yiannis
Tiger Master
Greece->Seattle->Barcelona
Bike: XC ABS
Re: Scotoiler
Reply #11 on:
December 04, 2010, 09:21:53 PM »
Are you guys using the "special" scotoiler oil in them or regular cheap machine oil?
Logged
Ted99uk
Tiger Member
Re: Scotoiler
Reply #12 on:
December 05, 2010, 08:31:52 AM »
Originally Posted by
GringoRojo
No, not overfilled. You park it on a left hand side side stand with hot summer sun on the number plate and reservoir and see what happens. No problem on a centre-stand.
I use special Scottoil.
Ted.
Logged
GringoRojo
Tiger Jedi
Bike: TigerXC ABS
Re: Scotoiler
Reply #13 on:
December 07, 2010, 12:34:55 AM »
fair enough. I only use the sidestand for short periods, never had a leak like that even when in the Spanish Pyrenees
Sottoil too even tho I know it's expensive.
Logged
Don T
Tiger Member
Bike: CB1000R & WR250R
Never again a chain driven bike without a Scottoiler.
Reply #14 on:
December 16, 2010, 09:02:17 PM »
I have used a Scottoiler (Vsystem) on my last two bikes.
On the first bike (a Versys) I connected a 200ml "lubetube" to the 50ml reservoir to insure that I had enough oil for longer rides/vacations.
When I got the Scottoiler dialed in (well lubed chain with minimum oil elsewhere) I discovered that I didn't need the Lubetube, as I only used about 50ml of oil in 20.000 km of riding.
I know that Scottoiler recommends a lot higher "flow-rate", but as my chain and sprockets were still in good shape when I replaced them at 54.000 km, I believe that they were sufficiently lubricated
On my current bike (a CB1000R) I have used the same recipe for adjusting the Scottoiler - and at 24.000 km the chain and sprockets looks allmost like new.
I allways use Scottoil by the way.
When I get a Tiger, one of the first things I'll do, will be to mount a Scottoiler.
Logged
“Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out and loudly proclaiming WOW - WHAT A RIDE!”
Tiger Tale
Tiger Master
Bike: 1050 Tiger DR650
Re: Scotoiler
Reply #15 on:
December 17, 2010, 06:26:02 AM »
doughnut
Anyone reckon a Scotoiler will fit on? Or thought about a way to keep the chain in good shape? I am coming from a belt drive BMW, so clearly i dont like messing around with oily stuff
Was the BMW your first ever motorcycle?
There are a few good reasons why chains are still used today.
The Scott Oiler is a good product for constant wet riding. Very few chain lube products will last long in rain, and forget the sticky gooey crap. Don't use it. The Scott Oiler flows oil constantly, makes a mess but keeps chain oiled and keeps relatively clean by constantly flowing oil which carries away grit. Good choice for wet riding ... but needs to be set up correctly, checked, refilled and regular bike cleaning a must. Too much oil will eventually get on your rear tire. Not good.
In dry environments like here in California we don't need oilers and few use them.
I don't mind cleaning/oiling my chain. Guess I'm used to it. I would 2nd the Dupont Teflon product as a good dry weather lubricant. Does not collect much grit, stays put OK. Not good in wet, will wear off in 5 minutes in real rain.
For cleaning I like WD40. Also, Kerosene or spirits take most chain lube off and also good for cleaning rear wheel, swing arm and such.
Keep off tires ... obviously.
Modern chains/sprockets are so good ... unlike the bad old days .... that even with zero chain care most of todays chains last ten times what old ones did just from 15 years ago.
Logged
Frenchie
Ex Member
Tiger Pro
Re: Scotoiler
Reply #16 on:
January 14, 2011, 10:56:59 PM »
As a fan of Scottoilers had an interesting conversation on this topic with the service manager at my local triumph dealer who had just carried out the 500 mile service on my roadster. If you fit a Scottoiler Vsystem yourself and cut into the vacuum side of the intake, and anything goes wrong, you have just invalidated your gaurantee...bugger. If , however, I buy Vsystem from said Triumph dealer, get them to fit it, and then something goes wrong, no problem, they will sort it. If I fit the electronic version which has only battery connections, then no problem, gaurantee stands in all instances..
Last Edit: January 14, 2011, 11:06:47 PM by Frenchie
Logged
Seed
Tiger Member
Bike: T800ABS on order
Re: Scotoiler
Reply #17 on:
January 14, 2011, 11:20:41 PM »
Hi doughnut,
I've got an Acumen electronic oiler on my Bandit 1250 and it's a great product. It operates via a solenoid with a flow rate map that is speed sensitive, so there's no vacuum connection. The lube itself is contained in a canister - when it's empty you just unscrew it and screw in a new one. Takes 30 seconds at most. Also, it doesn't fling onto the rear tyre as much as a Scottoiler. I highly recommend it.
Logged
Eschew obfuscation
jenkspj
Non-Active
Tiger Jedi
Own an 800 XC ABS - the cat told me to do it.
Bike: Tiger 800XC ABS
Re: Scotoiler
Reply #18 on:
January 15, 2011, 02:06:32 PM »
Have on on the 1050, will have on on the 800XC.
Not the silly computer driven one either.
As long as there is a spare vac port on the throttle body block all will be well.
Logged
doughnut
Tiger Master
Bike: White T800, ABS
Re: Scotoiler
Reply #19 on:
January 16, 2011, 12:01:00 AM »
Seed
Hi doughnut,
Wasn't aware of them, this looks great, cheers for the tip Seed
Logged
Print
Pages:
1
2
3
4
5
Go Up
Scotoiler
Recommendations for a 30k miles bike
chuckxc
Today
at 07:33:28 PM
Mitas E07+ for 800XC - Bias vs Radial
Tyres and Wheels
AvgBear
Today
at 05:44:40 PM
Tiger 900 turn signal dissassembly
krokodil
Today
at 03:35:40 PM
Madstad + Veo Vince + Triumph Machined Levers
For Sale
ronaldo
Today
at 02:38:27 PM
Reduce Throttle Pull on Throttle by Wire
Woody800
Today
at 07:03:20 AM
Tiger 800 Engine Covers
peterjfox69
Yesterday
at 08:19:43 PM
more servicing questions
AvgBear
Yesterday
at 05:26:56 PM
When will we be able to ride
On Two Wheels
PapaTom
Yesterday
at 03:52:30 PM
For sale tiger 800 xcx Downpipes will fit all 2015 with cat
For Sale
Big stu
Yesterday
at 01:05:02 PM
ABS Sensor rubbing ABS ring
SOHUTAA
Yesterday
at 12:14:17 PM
