Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Exhaust removal  (Read 2138 times)
Re: Exhaust removal
« Reply #10 on: July 14, 2012, 06:32:56 PM »
Will do.  All ready now to cut the cat.
Problems encountered so far;
Header nuts stuck.
Broke the header/mid pipe exhaust clamp
And that's it so far.
Offline BigMike
  • Bike: 800XC
Re: Exhaust removal
« Reply #11 on: July 14, 2012, 06:40:39 PM »
KM do you have a pneumatic drill?
Re: Re: Exhaust removal
« Reply #12 on: July 14, 2012, 08:17:19 PM »
*Originally Posted by BigMike [+]
I've the use of a big sds drill with chisel blades. Used the same drill to take up my kitchen floor tiles recently. Bloody powerful
Offline BigMike
  • Bike: 800XC
Re: Exhaust removal
« Reply #13 on: July 14, 2012, 09:24:21 PM »
that'll do  :008:
Offline C-J
  • Bike: 800XC ABS
Re: Exhaust removal
« Reply #14 on: June 18, 2018, 11:46:51 AM »
Header nuts stuck.
How did you get the header nuts out?  I've got to take my exhaust off to get a crack repaired and want to do it at home.  However, if I get it wrong then I've no way of getting it to the garage.
My bikes: Honda CBR600F, Triumph Daytona 600, Triumph Daytona 675, Triumph Scrambler, Yamaha TT250, Yamaha WR250, BMW1200GS, Triumph Speed Triple, Tiger 800XC, Ducati Multistrada DVT
If you're fed up of using sleeping pills check out my blog instead:
www.sprocket517.blogspot.com
Re: Exhaust removal
« Reply #15 on: June 18, 2018, 12:59:41 PM »
*Originally Posted by C-J [+]
Soaked with a penetrating oil from memory.  Left for a bit, tightened, then loosened and removed.
If in doubt then you might need someone with a range of tools.
Offline C-J
  • Bike: 800XC ABS
Re: Exhaust removal
« Reply #16 on: June 18, 2018, 01:09:12 PM »
Thank you, Triumph wanted to replace it (700!!!).  I'm going to take it off and get the crack welded.
Re: Exhaust removal
« Reply #17 on: June 18, 2018, 02:15:27 PM »
Offline C-J
  • Bike: 800XC ABS
Re: Exhaust removal
« Reply #18 on: June 18, 2018, 05:03:54 PM »
Tempting....
When you removed the cat did you have the bike re-mapped or was it okay?
Re: Exhaust removal
« Reply #19 on: June 18, 2018, 09:38:55 PM »
Tempting....
No remap needed.  Worked fine with the standard tune.
I did subsequently remove the lamda sensor and switched it off in tuneecu.  This makes it run a little richer.  Every check of sparks since have a nice colour - not lean and not rich.
