Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Exhaust removal  (Read 2001 times)
Re: Exhaust removal
« Reply #10 on: July 14, 2012, 06:32:56 PM »
Will do.  All ready now to cut the cat.
Problems encountered so far;
Header nuts stuck.
Broke the header/mid pipe exhaust clamp
And that's it so far.
Offline BigMike
  • Bike: 800XC
Re: Exhaust removal
« Reply #11 on: July 14, 2012, 06:40:39 PM »
KM do you have a pneumatic drill?
Re: Re: Exhaust removal
« Reply #12 on: July 14, 2012, 08:17:19 PM »
*Originally Posted by BigMike [+]
I've the use of a big sds drill with chisel blades. Used the same drill to take up my kitchen floor tiles recently. Bloody powerful
Offline BigMike
  • Bike: 800XC
Re: Exhaust removal
« Reply #13 on: July 14, 2012, 09:24:21 PM »
that'll do  :008:
Offline C-J
  • Bike: 800XC ABS
Re: Exhaust removal
« Reply #14 on: June 18, 2018, 11:46:51 AM »
Header nuts stuck.
How did you get the header nuts out?  I've got to take my exhaust off to get a crack repaired and want to do it at home.  However, if I get it wrong then I've no way of getting it to the garage.
My bikes: Honda CBR600F, Triumph Daytona 600, Triumph Daytona 675, Triumph Scrambler, Yamaha TT250, Yamaha WR250, BMW1200GS, Triumph Speed Triple and now a Tiger 800XC
If you're fed up of using sleeping pills check out my blog instead:
www.sprocket517.blogspot.com
Re: Exhaust removal
« Reply #15 on: June 18, 2018, 12:59:41 PM »
*Originally Posted by C-J [+]
Soaked with a penetrating oil from memory.  Left for a bit, tightened, then loosened and removed.
If in doubt then you might need someone with a range of tools.
Offline C-J
  • Bike: 800XC ABS
Re: Exhaust removal
« Reply #16 on: June 18, 2018, 01:09:12 PM »
Thank you, Triumph wanted to replace it (700!!!).  I'm going to take it off and get the crack welded.
Re: Exhaust removal
« Reply #17 on: June 18, 2018, 02:15:27 PM »
Offline C-J
  • Bike: 800XC ABS
Re: Exhaust removal
« Reply #18 on: June 18, 2018, 05:03:54 PM »
Tempting....
When you removed the cat did you have the bike re-mapped or was it okay?
Re: Exhaust removal
« Reply #19 on: June 18, 2018, 09:38:55 PM »
Tempting....
No remap needed.  Worked fine with the standard tune.
I did subsequently remove the lamda sensor and switched it off in tuneecu.  This makes it run a little richer.  Every check of sparks since have a nice colour - not lean and not rich.
