Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Headlight adjustment  (Read 3261 times)
Offline Nelizzz
  • Bike: Snot green
Re: Headlight adjustment
« Reply #10 on: June 20, 2017, 10:07:25 PM »
I could not adjust my headlight anymore, so I had a look at the ball joint.
And yes..  it was disconnected. Took me some time to get it in...
Some pics, last one ball joint connected again:
« Last Edit: June 20, 2017, 10:11:16 PM by Nelizzz »
Offline Turbo100
  • Bike: 17 Tiger 800 XRt
« Reply #11 on: June 20, 2017, 11:10:45 PM »
Just a note, my handbook says to raise the beam vertical you screw the adjuster clockwise,
If fact it's a misprint you screw it anticlockwise, outwards to raise the beam.
Offline fogi
  • Bike: Tiger 800 (2013)
« Reply #12 on: March 23, 2019, 01:45:31 PM »
Just for record.
I've got the same issue.
After studying the mechanics there, I can't image that this dealer solution can work:
i asked my triumph-dealer ans he said, that this a well known problem and there exists a official repair-instruction (also with video):
remove the screw with the lever, remove the lever from the screw, turn the screw back into the housing and strike with a (plastic)hammer on the screw.
the ball inside the housing shold spring back into the bearing. then install the lever again and the vertical adjustement works as it shold.
But I found a working one. You need to use a zip tie and a screwdriver, see pictures:
(Good to have a curved Kelly forceps also to roven the zip tie)
https://photos.app.goo.gl/p3THsw57d3815BWB9
