Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Lock Barrel Removal from Top Box  (Read 58892 times)
Offline arrybash
  • Bike: Tiger 800 XC
« on: February 26, 2013, 10:56:15 PM »
Does anybody have any tips to remove the lock barrel from the top box.  Looks like it needs to have the end tumbler moved as well as the lock tumblers.  I assume there is a master key, but I don't have access to one.
Chris
2013 Triumph Tiger 800XC
2012 BMW R1200 GS Adventure
2006 Yamaha TTR250
1989 Kawasaki ZX10
Offline GearHd6
  • Bike: 98 T595
Re: Lock Barrel Removal from Top Box
« Reply #1 on: February 26, 2013, 10:59:58 PM »
Contact a few dealers. I have been hearing that some dealers are starting to acquire a tool to remove the locks. Other than that you used to have to destroy either the box or the lock for removal.
2015 Tiger XCx
1998 Daytona T595
Offline rozzer
  • Bike: Speed Twin
« Reply #2 on: February 26, 2013, 11:21:50 PM »
Or you can get hold of a competant vehicle locksmith and they will do it without damage,they are the same cylinders as used in caravans and motorhomes.
« Reply #3 on: February 27, 2013, 10:02:24 AM »
Quite difficult to do.  The last pin locks in place and there is no key to release it.  Some just drill out old lock.  Some try to drill a precision hole into the last pin, lengthways.
Offline arrybash
« Reply #4 on: February 27, 2013, 03:13:34 PM »
I have tried to split the inner shell from the outer shell by removing all the torx screws thinking I would get access to the barrell.  However I failed to split the shells.
It may have split but I didn't want to damage anything as its a new top box.
I may get another key cut and try to use it as a master.  Past experience has indicated that if you can shove the key further (by filing it away) in it may release the locking tumblers.
Chris
2006 Yamaha TTR250
1989 Kawasaki ZX10
Offline GearHd6
  • Bike: 98 T595
« Reply #5 on: February 27, 2013, 03:22:55 PM »
Try dealer or locksmith.
2015 Tiger XCx
1998 Daytona T595
Offline healdem
  • ....has a fluffy tube
  • Bike: 2011 Tiger 800
« Reply #6 on: February 27, 2013, 04:52:28 PM »
Given Rozzer's in depth knowledge, Id be sore tempted to go down his route.....
Offline arrybash
« Reply #7 on: March 03, 2013, 11:11:10 AM »
Took my barrel and keys to a good vehicle locksmith.  The key already bottoms out past the locking tumbler hence its not possible to make any adjustments to a blank key.  Failed to get a solution at the locksmiths except to get a spare key cut.
Had another go at splitting the top box carcases.  Got all the torx screws out, however the pop rivets for the hinge are also through the two caracases, hence its not possible to split the carcases without drilling out the hinge pop rivets.  I don't want to butcher a brand new top box so I stopped at this point.  It is possible to prise apart the cascases above the lock by about 10mm, but it does not appear to be possible to actually release the lock.
Looks like the only way to remove the lock is to carefully drill out the internals to release all the tumblers, but then I would be a lock short for my set of 3.
In summary failed.
2006 Yamaha TTR250
1989 Kawasaki ZX10
Offline RaglandT
  • Bike: 800XC / 1200XRT
« Reply #8 on: March 03, 2013, 06:14:44 PM »
*Originally Posted by arrybash [+]
That is the first step.  Next step is to buy a new set of locks (pretty cheap) from your dealer and have them re-pinned to fit your existing key (or you can do it - pretty simple job), and put the new lock into the case.   :028:
Offline arrybash
« Reply #9 on: March 03, 2013, 09:10:21 PM »
The locks do not look as if they can be repinned to suit to ignition key, they look sealed units.  But maybe you get locks to the key number.
2006 Yamaha TTR250
1989 Kawasaki ZX10
