Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: What did you do to your Tiger today?  (Read 349390 times)
Slowmo, SteveTT800XRT, gryan39 and 6 Guests are viewing this topic.
Offline muddyrider
  • Gender: Male
  • Bike: Tiger XCA 800
« Reply #2940 on: December 31, 2017, 11:24:29 PM »
I washed and sprayed with ACF 50 for winter riding .. lovely and shiny now .. for a bit anyhow.
Aprilia 650 Pegaso, Kawasaki KLX 300 ,Honda CRF250X and Honda Fireblade
Online Bulldogfour
  • Gender: Male
  • Bike: Tiger 800XRT
« Reply #2941 on: January 08, 2018, 04:41:14 PM »
Swapped the front 100/90 Tourance Next for the 110/80 R version.  Only done 5 miles so not possible comment other than it feels slightly more flexible.
Only done 3k miles on the bike so far.  Front had gone down 1mm and the rear 1mm also.
Link to site that gives you comparisons between tyre sizes i.e. diameter and effect on speedo.
https://www.tacomaworld.com/tirecalc?tires=100-90r19-110-80r19
« Last Edit: January 08, 2018, 04:50:28 PM by Bulldogfour »
Bikes previous: NSU Quickly moped; Honda C50; Honda 305 scrambler; Yamaha RD350 (x2); Suzuki 380; Honda NX250; Harley Sportster 1200; Yamaha TDM900; Yamaha 1300 cruiser; Honda CB600F5 Hornet;
FJR1300 (x2); Triumph Explorer.
Bikes now: Triumph Tiger 800XRT - one bike less than optimum!
  • Gender: Male
« Reply #2942 on: January 08, 2018, 04:55:44 PM »
*Originally Posted by Bulldogfour [+]
Why did you change with so little wear on them?
Online Bulldogfour
  • Gender: Male
« Reply #2943 on: January 08, 2018, 05:14:15 PM »
After reading the experiences of others on here and also suffering from the front tramlining so often I decided that I'd rather have a more stable front tyre on the damp slippery roads we have at the moment.  I ride mostly rural roads and I do ride them progressively.
I've kept the old front so that I can put it to use if needed.
  • Gender: Male
« Reply #2944 on: January 08, 2018, 05:22:57 PM »
Ok, I've not had a problem with the Tourance Next, most reports i've read say it's a vast improvement over the previous Tourance.
But if I've read it right you're still on Tourance Next, just the slight different profile?
  • Gender: Male
  • Bike: 2016 Tiger XRt
« Reply #2945 on: January 08, 2018, 05:25:41 PM »
Might possibly be useful to someone  :084: .... but not relevant to the your tyre change as the speedo signal (on post 15 models) is provided by the rear ABS sensor & ring .... so unless you change the rear tyre size the speedo will be as accurate as it was before.  :028:
Online Bulldogfour
  • Gender: Male
« Reply #2946 on: January 08, 2018, 05:29:57 PM »
Ok thanks for that, good information.
Offline ubermick
  • Gender: Male
  • Bike: 2016 Tiger XCA
« Reply #2947 on: January 10, 2018, 07:10:28 AM »
Finally pulled a sickie, and got to work farkling her up. Installed a Fuzeblock under the rear tail, hardwired my GPS mount in (SW Motech behind the cluster mount) as well as a USB-fuelled x-grip, installed an Altrider rear rack, and replaced the factory handguards with Barkbusters VPS.
Givi Airflow windscreen is on the way, as well as a sidestand foot.
2016 Tiger XCA - Saoirse
Online Bulldogfour
  • Gender: Male
« Reply #2948 on: January 10, 2018, 08:16:09 AM »
Yes, Ive only changed the front.  Not noticed any issues with the Nexts apart from the tramlining.
Offline Shergar
  • Gender: Male
« Reply #2949 on: January 12, 2018, 09:25:28 PM »
Fitted a Pyramid fender extender, a Puig rear hugger and most importantly the stainless chain adjuster bolts from Adey. All fitted reasonably easily but having dropped the rear wheel out it was a bit of a pain to get back in. Then had to get Mrs Shergar to hold the bike upright while I adjusted the chain. Top marks to her for standing there and keeping the bike remarkably steady while I fiddled about.
All set now for a ride out Sunday morning if things go to plan :001:
