Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: What did you do to your Tiger today?  (Read 435154 times)
julesoxon, don085 and 4 Guests are viewing this topic.
Offline DarrylT
  • Bike: Tiger xrx
« Reply #3380 on: February 20, 2019, 07:38:04 PM »
Xrx 2015  :047:
Led headlights
Blue xenon parking light
Led stripes blue front / white back
Red light button switch installed as isolator
Heed hunker bars
Offline spoons
« Reply #3381 on: February 21, 2019, 01:37:11 PM »
Knocked it off the stand cleaning it  :138:
New brake lever required, did learn I can pick it up though.
Offline PapaTom
« Reply #3382 on: February 21, 2019, 03:59:46 PM »
Hard luck spoons.
I think you must be too vigorous in your cleaning methods.  :164:
Happy that you can see the good in your misfortune.
Online CB250G5
« Reply #3383 on: February 23, 2019, 04:20:18 PM »
Fired it up after 12,000 service.
Pondered what the error code meant, then refitted vacuum pipe to airbox, reset DTCs (thanks TigerTool) and all now OK.
10 shims changed, much suspension greased, etc etc.
Just bodywork to refit, then I can have a ride out, see if I like the 17T front sprocket.
2015 Tiger 800 XRx, Yamaha RD350YPVS special, Yamaha TDR250 (being rebuilt), Yamaha SRX400 Super Single and a Voskhod 175
Offline SOHUTAA
  • Bike: Tiger 800 Xcx
« Reply #3384 on: February 23, 2019, 06:05:51 PM »
Drain and replace fork oil Wp at 28000Kms.
Rinses with very fluid industrial oil.
I put Motorex in 5W.
Time: 3hoo taking without panicking, and especially tighten everything to the couple, given by the technical review.
Control of the bearings of the steering column - Ras.
Offline Steven clarkey
  • Bike: Tiger 800 xrx
« Reply #3385 on: February 23, 2019, 06:38:04 PM »
Took advantage of the surprisingly good day .got the bike out of my secure a bike garage gave it a quick check over , put a bit of air in the tyres then rode it for 125 miles .
This is the first time I've rode it in  3 month  it  started fist time and never mssed a beat.
It still the best bike I've owned  :417:
Online philmcglass
  • Bike: Tiger XRX 2016
« Reply #3386 on: February 26, 2019, 05:57:56 PM »
Headstock lubrication.
Thanks to Muddysump for the fine video.
Only snag was not removing Brake hose clamp at lower yoke.
Bit of a struggle getting it back together but wedged a 2 by 2 against the lower yoke with a jack and that helped.
Used CV joint grease but research says it is OK for small movement bearings.
« Last Edit: February 26, 2019, 06:06:58 PM by philmcglass »
Online philmcglass
« Reply #3387 on: March 01, 2019, 03:57:34 PM »
Fitted large Palmer Products adjustable screen.
Fairly straightforward.
Need a bt of a road test to get the best position.
Also cleaned out the pivot of the side stand. Got really stiff to swing down and up.
Regreased and now free.
Offline StretchToo
  • Bike: 800 XC 2013
« Reply #3388 on: March 01, 2019, 04:51:28 PM »
Green adjustable levers for a green bike, barkbusters fitted.
Then the next day rode it to work to test. Lever length adjustment not enough to get to ideal 2 fingers for off road, so not worth the bother, but they look good and quality is spot on.
Barkbusters not quite as good at wind/rain deflection as those givi inserts, but then the givi inserts broke on the first drop, being made out of stupid acrylic instead of sensible ABS like the unmarked standard handguard that was over them.
 An esteemed colleague also has excellent taste in motorcycles.
Offline Blue Flame
  • Bike: Tiger 800XRT
« Reply #3389 on: March 02, 2019, 09:35:17 AM »
Fitted a powerbronze sports screen. Buffeting gone  :046:
