Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: What did you do to your Tiger today?  (Read 506484 times)
Offline madwilly600
  • Bike: tiger 800
« Reply #3490 on: August 20, 2019, 09:10:53 PM »
 Sun shone.. Captain Jasper's breakfast then  treated to a ride out around the South Hams Devon, Modbury, Kingsbridge, Dartmouth,Totnes, Bovey Tracey, Mortonhampstead, Princetown. Lovely weather great ride out with mates.. 64.5 MPG for those who care!!
so lucky to live in Gods Own...
Offline Clive
  • Bike: Tiger 800 xrx
« Reply #3491 on: October 03, 2019, 10:08:57 PM »
Hi Ive just ordered the powerbronze screen for my bike due to wind noise and buffeting can I ask is the screen still adjustable for height when fitted
Clive
Offline stevedo
  • Bike: 800XC
« Reply #3492 on: October 04, 2019, 05:08:20 AM »
Took the opportunity to do the following to Tigger in Santiago de Chile on our RTW ride:
66,000 mile service
check valve clearances - all inlets tight
balance injectors
change coolant
change spark plugs
change brake fluid
fitted new tapered steering head bearings
fitted new endless D.I.D. chain and sprockets
greased rear suspension
new brake pads all around
new front EBC brake discs
replaced rear brake pad pin
replaced brake calliper rubber boots front and rear
replaced front master cylinder diaphragm
fitted new UniFilter prefilter
fitted new airbox seal
gear return pin repaired and return spring replaced
applied JB Weld to swingarm to "repair" wear marks created by chain rubbing strip
fitted new front beak support moulding
replaced the captive nut behind the catalytic converter cover as it had rusted away
cleaned electric connectors and greased with dielectric grease
converted rear spoked wheel to tubeless using Outex kit
fitted new Heidenau K60 rear tyre
rubbed down and resprayed Jesse luggage pannier frames
removed rust from mirror stems
fitted Rotopax 6.6 litre fuel can
fitted new GPS cradle for Zumo 595 (replaces failed Zumo 660)
fitted new extended chainguard
replaced two upper rubber support "washers" for radiator
pretty much disassembled, cleaned and reassembled bike
had my Nitron shock absorber serviced in the UK
Obviously not all done in one day but over a few weeks. All done now and ready for the next 70,000 miles or so :-)
My full maintenance log, including photos, can be seen at http://www.tiger800rtw.com/tigger-maintenance-repair/ (no adverts, I don't attempt to monetise my blog)
Saludos
Steve
www.tiger800rtw.com
Facebook @tiger800rtw
Orange 800xc ABS travelling around the world. Currently in Chile. www.tiger800rtw.com or https://www.facebook.com/Tiger800RTW/
Offline mcinlb
  • Bike: 2018 Tiger 800
« Reply #3493 on: October 04, 2019, 08:58:00 AM »
The phrase "Triggers Broom" comes to mind  :001: :001: :001:
Offline Oldfart
  • Bike: Tiger800 XRt
« Reply #3494 on: October 04, 2019, 02:27:04 PM »
*Originally Posted by mcinlb [+]
Mangetout mangetout and the French havent a word for entrepreneur as Del would say
Oldfart
Triumph XRt & America
« Reply #3495 on: October 04, 2019, 10:38:14 PM »
Showed that it's possible to get down to 0mpg if you try hard enough. All you have to do is fill it with diesel.
Fortunately I realised before starting it up but unfortunately after filling it to the top. Had to get it extracted. And then I discovered that both dip beams had blown, so I rode the 35 miles or so back home on full beam, dazzling everyone else.
That was actually two days ago. I think I can manage to confess to it now.
Offline jhampshire
  • Bike: Tiger 800 ABS
« Reply #3496 on: October 05, 2019, 12:35:44 AM »
At 45,000 miles on my 2012 Tiger800ABS I flashed the ECU with 21066 map. I have not ridden it a long way but the throttle response seems less vicious and lean popping is reduced.  Now to find a map for the Leo Vince pipe I removed a year ago.
Offline stevedo
  • Bike: 800XC
« Reply #3497 on: October 09, 2019, 05:34:26 PM »
Surely you mean "Tiggers broom"   :001: :001: :001:
PS: Yes I am aware of the Trigger to which you refer  :001:
« Reply #3498 on: October 25, 2019, 12:54:42 AM »
Wednesday afternoon, oil and filter change ready for going off to Lake District Friday mid-day.
Finally fitted alloy magnetic plug from Square deals bought back in March 18.  :164:
Offline SOHUTAA
  • Bike: T800 Xcx 2016
« Reply #3499 on: October 27, 2019, 02:03:10 PM »
At home replacement of the Pirelli trail II Rear at 8000 Kms. Balancing included.
