Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Cat delete  (Read 2451 times)
Re: Cat delete
« Reply #10 on: May 17, 2013, 07:36:18 AM »
*Originally Posted by Dynodusty [+]
No doubt the bike needs to be mapped with an aftermarket muffler, heck even the stock bike needs help as I found it to be quite lean.  I run mine at 13.8 in cruise and 13.2 everywhere else.
Thought the maps we're done on throttle opening and revs. How do you define cruise?
Offline Dynodusty
  • Bike: Tiger 800xc
Re: Cat delete
« Reply #11 on: May 17, 2013, 05:30:37 PM »
"Cruising down the highway in 6th I find myself at 9-11% throttle and around 4500rpm, in town in 3-4th gear I am around the same area.  So I setup this are in my Power Commander 5-15% throttle and 4000-5000rpm leaner than the rest of the map.  I may take this a step further and wire in the Gear Position to the PCV so that I can only lean out this area in 4-6th gears and leave 1-3rd richer.
Offline Steve L
Re: Cat delete
« Reply #12 on: October 10, 2018, 11:26:15 AM »
Did removing the cat make much difference to the sound
Re: Cat delete
« Reply #13 on: October 10, 2018, 12:09:52 PM »
*Originally Posted by Steve L [+]
Yes for me (keeping the housing) the sound is deeper.
Offline Steve L
Re: Cat delete
« Reply #14 on: October 10, 2018, 08:56:45 PM »
Offline Free-Spirit
  • Bike: Tiger 800XRt
Re: Cat delete
« Reply #15 on: October 11, 2018, 08:28:36 AM »
Can removing the CAT have any affect re passing the MOT? Just curious. Thanks.
Offline Steve L
Re: Cat delete
« Reply #16 on: October 11, 2018, 08:41:41 AM »
only if you tell them  :007:
Online healdem
  • ....has a fluffy tube
  • Bike: 2011 Tiger 800
Re: Cat delete
« Reply #17 on: October 11, 2018, 09:42:11 AM »
if you remove the cat and replace with a piece of pipe I doubt y'd need to tell 'em  :017:
Offline Guyver
Re: Cat delete
« Reply #18 on: October 11, 2018, 12:47:43 PM »
*Originally Posted by Free-Spirit [+]
Most new bikes come with a cat fitted. So most MOT stations will know which bike should have one fitted and can and will fail such bikes. Not worth the risk for so little gain.
Re: Cat delete
« Reply #19 on: October 11, 2018, 01:22:43 PM »
Which is why I left the cat chamber in place.  The gain for me was a cooler foot.  Each to his own.
