Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Service videos  (Read 47217 times)
Offline RogerRamJet
  • Bike: Tig 800
Re: Service videos
« Reply #140 on: January 27, 2016, 05:26:24 PM »
*Originally Posted by MuddySump [+]
You can check the last 6 digits of your vin number. If it starts from 601012 or later then it's one of the ones that needs the adjustment.
602750 - makes me a lucky winner !!!  :006:
I think i'll try giving the shop where the bike was purchased a call and see if they have any record of the 12K service being done.
Thanks again for the info
Offline MuddySump
  • Non-Active
Re: Service videos
« Reply #141 on: January 27, 2016, 05:33:56 PM »
Not to get the cams out. It's just so the sprockets move to take out the initial cam chain stretch
UK based mobile mechanic
Annual service 125
6k service 155
12k service 360
24k service 400
Offline MuddySump
  • Non-Active
Re: Service videos
« Reply #142 on: January 27, 2016, 05:35:33 PM »
I don't even think there is a way of knowing if it has been done if they're not sure.
Annual service 125
6k service 155
12k service 360
24k service 400
Offline GearHd6
  • Bike: 98 T595
Re: Service videos
« Reply #143 on: January 27, 2016, 05:39:19 PM »
Oh ok, so without the tool the cams and timing will be like they were prior to the cam removal. The tool just gets everything back to factory spec provided there has been chain stretch. Thanks.
2015 Tiger XCx
1998 Daytona T595
Offline MuddySump
  • Non-Active
Re: Service videos
« Reply #144 on: January 27, 2016, 05:42:20 PM »
The tools lock the crank in place and the cams in place so the screws on the cam sprockets can be removed and new screws fitted. It only gets done in the first 12k service and you don't need the tools any more after that
Annual service 125
6k service 155
12k service 360
24k service 400
Offline MuddySump
  • Non-Active
Re: Service videos
« Reply #145 on: January 27, 2016, 05:50:13 PM »
On an explorer but same on the 800
Annual service 125
6k service 155
12k service 360
24k service 400
Offline GearHd6
  • Bike: 98 T595
Re: Service videos
« Reply #146 on: January 27, 2016, 06:01:31 PM »
So even if your valves don't need to be adjusted, that timing procedure should be done at 12k?
2015 Tiger XCx
1998 Daytona T595
Offline MuddySump
  • Non-Active
Re: Service videos
« Reply #147 on: January 27, 2016, 06:05:07 PM »
Yes. Even if they're in spec it all needs to come apart for the timing
Annual service 125
6k service 155
12k service 360
24k service 400
Offline GearHd6
  • Bike: 98 T595
Re: Service videos
« Reply #148 on: January 27, 2016, 06:09:41 PM »
Alright. Thank you very much for the explanation. That's much different than  my early 2011 was then.
2015 Tiger XCx
1998 Daytona T595
Offline MuddySump
  • Non-Active
Re: Service videos
« Reply #149 on: January 27, 2016, 06:12:36 PM »
Yea. They say you should notice the difference when it's done if you've rode the bike the whole time
Annual service 125
6k service 155
12k service 360
24k service 400
