Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: How Often due you lube your chain?  (Read 14952 times)
Offline davamb
  • Gender: Male
  • Today will be difficult, but tomorrow- good riding
  • Bike: 800 XRx
Re: How Often due you lube your chain?
« Reply #70 on: April 21, 2017, 02:37:42 AM »
Zoomed in and had a closer look. Appears that the oil is delivered (inboard) to the pad underneath the chain, not to the top of the chain. Having said that, the chain does seem to be pretty dry and not sure how long the pad will last. Still, an interesting take on the idea. Would like to see some more pics from different angles.
Cheers,
Dave
« Reply #71 on: April 21, 2017, 03:18:19 AM »
That makes sense.
Offline Derchef1962
  • Gender: Male
  • Bike: White 800 Roadie
« Reply #72 on: April 21, 2017, 07:12:12 AM »
back to the OT :
I lube about every second tank stop with drylube, first chain lasted about 35,000 kms so I am not complaining
Live is too short to drink bad wine or to ride bad bikes.
Offline Frosties
  • Gender: Male
  • Bike: Tiger 800 (ABS)
« Reply #73 on: April 21, 2017, 07:25:27 AM »
Usually every weekend after commuting 280'ish miles during the week. I also use Putoline ceramic chain wax. Original chain lasted 23k miles. Second chain and sprockets only last 7k miles as I was using an oiler. Back to the ceramic wax on my third chain and so far so good - already at 6k miles and only had to adjust once.
Offline Turbo100
  • Gender: Male
  • Bike: 17 Tiger 800 XRt
« Reply #74 on: April 21, 2017, 11:26:51 AM »
You must be looking at a different photo than I am then. The photo I linked to above quite clearly shows the oil being applied to the outside of the chain.
Fitting and layout of Scottoiler for Tiger 800
https://www.scottoiler.com/component/option,com_docman/Itemid,/gid,715/task,doc_download/
Offline Atila
  • Gender: Male
  • Bike: 2016 Tiger XCA
« Reply #75 on: April 21, 2017, 02:55:43 PM »
*Originally Posted by Frosties [+]
Interesting difference.  How often do you clean your chain?
Enviado desde mi SM-G925I mediante Tapatalk
Offline Frosties
  • Gender: Male
« Reply #76 on: April 21, 2017, 03:43:03 PM »
I usually wipe it don't before reapplying lube. I don't clean it properly with WD-40 or paraffin or anything. But that was the case for all my chains.
