Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Rear shock  (Read 7573 times)
Offline wuckster
  • Bike: T800 White
Rear shock
« on: February 28, 2011, 08:09:24 PM »
Hi,
I note that the rear shock/shock linkage sticks out under the bike quite a bit and is right in the firing line for crud off the road and back tyre.
I know a hugger will stop some of this if and when one is produced, anyone else got any other ideas or suggestions to prevent this from happening apart from religious cleaning and re-greasing ?
Still not taken the plunge, but wavering !
Cheers,
Andy
Tigger 800 road (White)
Offline oneorangedog
  • Non-Active
  • Bike: white xc
Re: Rear shock
« Reply #1 on: February 28, 2011, 08:21:18 PM »
i have bought a shock sock to cover the spring.
http://www.reactivesuspension.com/accessories.php
if you turn it inside out - the horrible white logo can't be seen, and the velcro still works - just reversed.
not sure how you protect the linkage... grease?, waxoyl?
« Last Edit: February 28, 2011, 08:39:28 PM by oneorangedog »
Offline t8coco
  • Bike: SPEED TRIPLE R
Re: Rear shock
« Reply #2 on: February 28, 2011, 08:25:25 PM »
 have found a spray of scotoiler 365 protector every now and then has done the job before  :152:
 will be using it on my tiger, splash it all over Harry  :008:
Steve
Re: Rear shock
« Reply #3 on: February 28, 2011, 09:13:48 PM »
As mentioned a Traxxion shock sock.  But I actually like the logo
Stupid is as stupid does.
IRL via GB & CL
Offline foey
Re: Rear shock
« Reply #4 on: March 01, 2011, 08:12:33 AM »
I put some 3mm rubber sheet  between the shock & swingarm on my old Tiger 1050, i fixed it in place with velcro somewhere up under the seat & cut channels in it so it fitted over the linkage completely covering it, it worked a treat, will be looking to do a similar thing on the 800 if the opportunity is there.
Offline Birdy68
  • Be prepared to change your plans.
  • Bike: T'Bird & T800XC
Re: Rear shock
« Reply #5 on: March 07, 2011, 12:21:07 PM »
*Originally Posted by oneorangedog [+]
What length did you order - 6", 7" or 8"?
Was it the right size or would you recommend different?
Thanks in advance.
Birdy68
-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-x-
Leave the pork pies for now - get the sausage rolls while they're hot!
  • Non-Active
  • Bike: white xc
Re: Rear shock
« Reply #6 on: March 07, 2011, 12:24:30 PM »
8" fits ok, bit fiddly to fit but ok when on.
turn it round so breather holes are opposite rear wheel
Offline cunestu
  • Bike: Blue XRx
Re: Rear shock
« Reply #7 on: March 07, 2011, 12:26:25 PM »
You need a 9" sock Birdy68 - In addition to those quoted above, R&G also make them.   http://www.rg-racing.com/browseType/Shocktube/Triumph/Tiger_800/SHOCK1BK.aspx
Sometimes I like to squat down, put my arms around my legs and lean forward but that's just how I roll.
Offline Birdy68
Re: Rear shock
« Reply #8 on: March 07, 2011, 12:51:26 PM »
Thanks for the input!  :031:
Birdy68
Re: Rear shock
« Reply #9 on: March 07, 2011, 01:54:26 PM »
My 8" shock sock fits fine.
IRL via GB & CL
