Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Front Fender riser kit Engineering  (Read 9381 times)
Offline SMIFFXC
  • Bike: XC BLACK ABS
Re: Front Fender riser kit Engineering
« Reply #20 on: June 08, 2011, 10:28:58 AM »
Here are a coule of pic's to show what raising it 20MM gets with a knobby tire.
Offline GIDEON
  • Learn it! Life it! LOVE IT!
  • Bike: Tiger 800 XC
« Reply #21 on: June 08, 2011, 11:42:00 AM »
Thats just awesome
the Tiger look the part with knobby's
"Horsepower is an illusory Mathematical equation
 Torque is the source of all Good things in the world"
-Nobody can be exactly like me. Sometimes even I have trouble doing it-
Offline SMIFFXC
« Reply #22 on: June 09, 2011, 12:42:30 AM »
*Originally Posted by GIDEON [+]
Thats just awesome
Yes, I have to agree.  You do pay for it in the handling dept on pavement.  I took off today at lunch forgetting I had these on and the back end started to fishtail right around, kind of cool actually.   :007:  The back tire looks quite nice as well.  I can't wait to try them out in the dirt!
Offline Strada
« Reply #23 on: June 09, 2011, 07:45:48 AM »
Can you even raise the fender by 20mm.  Looking at mine, 800 not xc, I would say there's no room to raise the fender at all, unless you replace the brake lines with straight runs from the master cylinder and do away with the loop over the fender.
Has anyone checked the suspension travel to see if there's contact on full jounce?
I fitted a stebel horn under the beak and did a quick measure up and there wasn't much to play with so had to tuck the horn up inside the beak cavity.
Offline Have a cup of tea
  • Bike: Tiger 900 Pro
« Reply #24 on: September 20, 2011, 10:36:11 PM »
Modified SMIFFXC design slightly,
when you take the fender off you will see a plastic cover this is held in with a little plastic screw, remove this you can the line up the original bolt hole at the bottom of the fender with this and insert a 12mm M6 bolt (used button flange) makes it look a bit neater IMHO. other wise the same.  :002:
Bikes
Tiger Rally Pro
Ex 800 XC owner ( the original silver frame)
Puzey XTR-4 300 Enduro
Offline soph9
  • Bike: 2010 BMW F650GS
« Reply #25 on: September 25, 2011, 06:13:46 AM »
we used Touratech front fender risers on our Triumph Tiger 800XC summer trip....$40 US
http://www.touratech-usa.com/Store/3358/PN-420-5441/Front-Fender-Riser-Triumph-Tiger-800
Easy to install...not expensive and worked
advgrrls.com
« Last Edit: September 27, 2011, 04:31:03 AM by soph9 »
Maple Ridge, BC Canada
Offline fred88
  • Bike: Triumph 800 xc
Offline blacktiger
  • Bike: Tiger800XC
« Reply #27 on: May 07, 2012, 11:16:11 AM »
*Originally Posted by Strada [+]
Burren Rider broke his mudguard by raising his too far. You'll have to search through this thread http://www.advrider.com/forums/showthread.php?t=704559 I think he worked out that on full bump there's only 8mm clearance between guard and bottom yoke as standard. So even with the 15mm of the Touratech kit you're going to hit the guard. I'm hoping that there's enough flex in the guard to accommodate the other 7mm. Any more than 15mm beware.
Offline GIDEON
« Reply #28 on: May 08, 2012, 07:56:13 AM »
Mine also broke on my AAAGH Moment.
And thanks for the info.
 :460:
Might have to reduce it to 15mm. Is this tested or under development  :008:
Because I can make it smaller and test it for us at 15mm  :492: :492: :492:
Offline Ozmodias
  • Per Aspera, Ad Astra
« Reply #29 on: October 26, 2020, 08:59:47 PM »
Can someone update on making the blueprints for raising the fender with 15mm? Is it true that if you raise it more you will have issue with the radiator?
Τὰ μέλλοντα μὴ ταρασσέτω:ἥξεις γὰρ ἐπ̓ αὐτά,ἐὰν δεήσῃ,φέρων τὸν αὐτὸν λόγον ᾧ νῦν πρὸς τὰ παρόντα χρᾷ
