Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: 2018 XRX Fuse Block  (Read 751 times)
Offline captainjm
  • Bike: Tiger 18 800 XRX
2018 XRX Fuse Block
« on: October 20, 2019, 08:16:04 PM »
Any advice on fitting a fuse block for 2018 800  xrx. I want to supply GPS, heated vest, scottoiler
Who supplies the block etc
Offline Oldfart
  • Bike: Tiger800 XRt
Re: 2018 XRX Fuse Block
« Reply #1 on: October 20, 2019, 09:51:06 PM »
I use one of these, easy to fit
https://innovv.co.uk/products/powerhub/
Oldfart
Triumph XRt & America
Offline mcinlb
  • Bike: 2018 Tiger 800
« Reply #2 on: October 21, 2019, 08:34:53 AM »
I fitted a "FuseBlock" on my 2018 XRX, removed the plastic thing on top of the battery and mounted it atop the battery with a piece of thin foam sheet between. Uses the rubber band to keep it in place, no issues in the last year...
Offline Nelizzz
  • Bike: Snot green
« Reply #3 on: October 21, 2019, 11:35:30 PM »
I use PDM60, not cheap but fancy.
Online K1W1
« Reply #4 on: October 22, 2019, 03:02:42 AM »
Eastern Beaver 3CS. Three circuits and you can buy a switched or unswitched set up.
Offline Little H
  • Bike: Tiger 800 XRXLow
« Reply #5 on: October 22, 2019, 08:12:21 AM »
I use this from Nippy Norman's in Paignton, bit expensive though now.
https://www.nippynormans.com/fuse-panels/fuzeblock-switchable-fuse-panel
It's fitted on an insulated base under the pillion seat and uses the tool kit rubber strap to keep it in place.
« Reply #6 on: October 22, 2019, 09:21:05 AM »
K1W1 has it. Eastern Beaver 3CS. Great little fuse block.
