Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Starting problem  (Read 841 times)
Offline Robin Catbush
Starting problem
« on: November 25, 2020, 06:42:43 AM »
Hi everyone, I have a Tiger 800 2012 and it's just developed a starting problem,
It's as if it's not getting the extra fuel needed on cold start, like a choke would give, when it's going in runs fine, anyone else experienced this...???
Offline Johnjo
  • Bike: 800 xrt
Re: Starting problem
« Reply #1 on: November 25, 2020, 08:27:52 AM »
Not sure about the pre ride by wire 800's.
If it's only started this behaviour with the cold weather change try cracking the throttle before you hit the starter. This technique used to be in the manual when I had a 1050 tiger.
If it's a mechanical problem someone will be along to help.
Offline grizzlybear
  • Bike: tiger 800Xr
« Reply #2 on: November 25, 2020, 02:37:58 PM »
Could be the 'sticky Stepper Motor' problem. Do a search and you will find loads of help
Safe Riding
Offline characticus
  • Bike: 2018 XRx
« Reply #3 on: November 25, 2020, 03:22:40 PM »
Could well be a temperature sensor problem, either the Inlet Air (IAT) sensor or Coolant (ECT). I don't have the data for the earlier Tiger, but the IAT will be located in the airbox, the ECT in the cylinder head. You can test these by resistance measurements with a multimeter or maybe by reading sensor data via OBD port - TuneECU may give this?
Offline grizzlybear
  • Bike: tiger 800Xr
« Reply #4 on: November 25, 2020, 03:30:28 PM »
Does sound like A Stepper Motor problem
Safe Riding
« Reply #5 on: November 26, 2020, 10:00:50 AM »
Thanks for the suggestions chaps, I'll let you know...😁👍☘️🇮🇪😷
