Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: 2015 tiger not running properly 🙁  (Read 1348 times)
Offline eelblady
  • Bike: 800 xrx
« on: December 15, 2020, 08:18:04 PM »
Had the tank and everything off to check the valve clearances (all in range after 20k but exhaust  valves mostly right at the tight end).
Put back together, started fine, engine light came on and now struggling to keep it running after start up - once it is idling it’s okay but hard to get it there.
Can’t get tiger tool working (better cable on order) so no  codes read yet. Guessing it’s a bad reconnection on a sensor but any pointers to narrow it down, please?
Many thanks
Offline PapaTom
Re: 2015 tiger not running properly 🙁
« Reply #1 on: December 15, 2020, 10:08:06 PM »
Hi.
Did you reconnect the small bore rubber pipe back onto the map sensor?
« Reply #2 on: December 15, 2020, 10:37:12 PM »
I haven't quite got to the tank removal point myself but on what I've learnt here over 5yrs 99% of issues after tank removal are the small bore sensor pipe being missed and not reconnected on reassembly as Papa Tom says.  :084:
Offline eelblady
  • Bike: 800 xrx
« Reply #3 on: December 16, 2020, 08:42:50 AM »
Thanks both. It was indeed that pipe! Could just get to it with the tips of my fingers. Starts and idles fine now - will give it a test ride later
I really didn't fancy taking the beak, side panels, fog lights and then the tank to investigate further.
Thanks again
Offline PapaTom
« Reply #4 on: December 16, 2020, 06:01:42 PM »
You're welcome.
That's what we are all here for....
Each other.
Deep!
Offline taff
  • Bike: Tiger XC
« Reply #5 on: December 16, 2020, 06:19:52 PM »
We've all been there and done that   :047:
Offline eelblady
  • Bike: 800 xrx
« Reply #6 on: December 17, 2020, 08:14:44 PM »
 :028:
Offline Flappy613
  • Bike: '15 Purple XCx
« Reply #7 on: December 19, 2020, 01:30:04 AM »
Thank you So much for that.
Makes sense of just "why" they kept Matilda after they broke hers when at dealer.
"You start it, I'll finish it. " - Bob Hannah
