I second Steve P's comments. changed my original for the new one when I got excessive wear on the front edges of the rubbing strip. mind you this was at 30K. and after postings started to appear about swing arm wear. The later type has a top and bottom shock insert, I think this is to reduce the chance of wear on the lower front of the swing arm. Done over 10k on the new one with no sign of any excessive wear.
