Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
February 27, 2021, 12:49:54 AM
Home
Forum
Search
Members Map
Photos Gallery
Login
Register
Triumph Tiger 800 Forum
OD of Spacers for Rear Wheel - Tiger 800XC 2011-2019
Print
Pages: [
1
Go Down
Author
Topic: OD of Spacers for Rear Wheel - Tiger 800XC 2011-2019 (Read 887 times)
Nathompson1
Tiger Cub
Bike: Tiger 800XC
on:
January 04, 2021, 09:08:50 PM »
Need some help here...
I am working on a build and am using the rear wheel from a Tiger 800XC (Years: 2011 - 2019).
The swing arm on the bike is wider than the swing arm of the Tiger so I need to make some new spacers.
To my question... what is the OD of the spacers on the Tiger 800XC?
I need to the dimensions to make sure the spacers seal correctly against the bearings in the wheel.
Any help you can provide would be great!!
Best,
Adam
Logged
pme
Tiger Member
Bike: xrx lrh 2018
Re: OD of Spacers for Rear Wheel - Tiger 800XC 2011-2019
Reply #1 on:
January 05, 2021, 09:12:01 AM »
Hi Adam
2016 xcx has a 28mm OD. If you have a good look on the oil seal you should be able find a reference number to look up the spec for the seal.
Hope that helps
rgds
chris
Logged
Nathompson1
Tiger Cub
Bike: Tiger 800XC
Reply #2 on:
January 05, 2021, 03:18:40 PM »
Thanks for the quick response!
I took a quick measurement last night and it looks like something around 35 mm.
Does that sound right?
Assuming to OD would be different based off of the wheel right?
Best,
Adam
Logged
pme
Tiger Member
Bike: xrx lrh 2018
Reply #3 on:
January 05, 2021, 06:13:38 PM »
its a top hat shape the "brim" is 34mm, the part into the seal is 28mm
this is the rear wheel
Logged
Nathompson1
Tiger Cub
Bike: Tiger 800XC
Reply #4 on:
January 05, 2021, 06:37:31 PM »
So the Silver part on the right is 34/35 mm and the black piece is 34 mm on the left and 28 mm in the middle... correct?
Best,
Adam
Logged
pme
Tiger Member
Bike: xrx lrh 2018
Reply #5 on:
January 06, 2021, 11:17:54 AM »
the silver part may be part of the spacer inside between the bearings?
see attached picture of what i measured
Logged
D6864
Tiger Master
Bike: White XC
Reply #6 on:
January 06, 2021, 03:06:19 PM »
The silver part is the left hand spacer between the sprocket carrier and the swingarm, 35mm o/d
Logged
Nathompson1
Tiger Cub
Bike: Tiger 800XC
Reply #7 on:
January 06, 2021, 03:13:55 PM »
Got that... what's the OD of the right hand spacer?
Something like 28 mm?
Best,
Adam
Logged
Londonglide
Tiger Pro
Bike: xc
Reply #8 on:
January 06, 2021, 05:07:53 PM »
I've got the two original outer spacers on the desk, having replaced them with VFR Pauls Titanium ones.
The Chain side, straight spacer has an OD of 34.92mm so nominal 35mm, and the other, mushroom shaped one for the brake side is 28mm OD at the oil seal position
Both have an ID of 20.1-20.2mm
Logged
Print
Pages: [
1
Go Up
Ugly ticking sound from engine, 2013 Tiger 800 XC
Rauno_N
Yesterday
at 10:37:08 PM
Hi from atuttogas
New Members
TIger Lad
Yesterday
at 10:03:39 PM
Madstad + Veo Vince + Triumph Machined Levers
For Sale
Despina
Yesterday
at 09:32:43 PM
Gone over to the dark side.
On Two Wheels
GeoffS
Yesterday
at 08:23:02 PM
Got the new baby home! :)
rayjay
Yesterday
at 07:50:47 PM
Electronic gremlins
Misc Technical Help Required
Djairouks
Yesterday
at 02:56:34 PM
Givi topcase plate M9B/M9A
Accessories and Products
OHRider
Yesterday
at 12:19:16 PM
When will we be able to ride
On Two Wheels
Paulhere
Yesterday
at 11:54:49 AM
Mitas E07+ for 800XC - Bias vs Radial
Tyres and Wheels
dragon88
February 25, 2021, 11:39:26 PM
REGINA MAINTENANCE FREE CHAIN
AvgBear
February 25, 2021, 06:29:25 PM
