Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Handle bar risers  (Read 1167 times)
Offline Alan215
  • Bike: Triumph tiger
Handle bar risers
« on: September 14, 2021, 01:14:59 AM »
Hello looking to see if this is a good idea or not I have a triumph tiger 800 14 plate and I seem to be leaning forward on my wrist so thinking of buying handle bar risers we I have to alter cables ect or is it a bolt on
Offline dragon88
Re: Handle bar risers
« Reply #1 on: September 14, 2021, 02:26:02 AM »
a set of 2" Rox risers or similar is the most common upgrade and requires nothing more than a cable re-route. 20 minute, easy job.  FYI, regardless of what some might say. DO NOT buy the cheap chinese risers. Spend a few bucks more on proven quality.
« Reply #2 on: September 14, 2021, 08:48:56 AM »
*Originally Posted by Alan215 [+]
... I have a triumph tiger 800 14 plate ...
You don't indicate if it is a roadie or XC bike which may be relevant, I don't know the standard setup. Not sure on the 'Gen 1' bikes but on the 'Gen 2' the roadie (XR) didn't come standard with a high riser (but a short one) and the XC did. I had the Triumph XC riser fitted as an accessory to my roadie at PDI and also reversed as that brings the bars up and closer. I then later also fitted Rox risers on top of those and the only thing I had to do was relocate the 'Triumph' rubber band cable ties from being on the bars (pic 1) to just the cables (pic 2 & 3) to remove tension on full steering lock.
https://www.tiger800.co.uk/index.php/topic,28513.0.html
The risers I show on page 2 to indicate the reversal system are the standard factory low roadie ones I had taken off.
Offline Abramsgunner
  • Bike: Tiger 800 XC ABS
« Reply #3 on: September 21, 2021, 08:23:01 PM »
I went with 2" Rox Risers and the ProTaper EVO Adventure bars..    very happy with the results on my 2014 800 XC.
I absolutely hated the stock bars in every way possible.. too short, too straight.. my wrists/arms/shoulders/lower back were not impressed.   I tried the stock Explorer (1200) bars, both with and without the risers and while they were better, they still hurt me.
The EVO Adventure bars sweep back enough for my wrists, and are tall enough to let me sit or stand in comfort.
The Rox risers also let you cheat the bar back a bit...  think 45 degrees vs. straight up, so that the bars are a little taller and a little closer to you.
EDIT: I used the EVO Adventure... not the EVO Adventure High
EDIT 2:  I may have cut about a half inch off each side of the handlebars and added real handguards...  cables took a little fiddling but everything worked out OK.
« Last Edit: September 21, 2021, 08:28:02 PM by Abramsgunner »
'14 Tiger 800 XC ABS, '09 Kawasaki KLX331S
Offline Newhorizons
  • Bike: 2015XC
« Reply #4 on: September 22, 2021, 08:41:20 AM »
Explorer Bars are pretty good. There are lots here who have done that and very happy.
I removed my risers after doing explorer and did a thread on why you want to fit them and a how too tutorial.
But go and grab a set of aftermarket bars and put them next to your, sit on an Explorer and then it will make sense.
But, its not an easy job, just saying.
Offline Alan215
« Reply #5 on: September 22, 2021, 08:51:12 AM »
Just an update fitted the Rox risers to my tiger 800 and it has changed the bike completely even to the position were I sit on the seat used to sit touching the tank now sit so the rear seat is touching my bum it has brought them up and back about 45 degrees why I did not do this long ago
Offline Q
  • Bike: 800 XCA
« Reply #6 on: September 22, 2021, 11:15:55 AM »
agree - even the standing position is far better once the up & back Rox Risers were fitted
having a quiet chuckle every time I see some comment about the 900's sitting/standing position not being optimal - the 800 is perfect IMO now that the positioning of the handlebars have been addressed
Offline OHRider
  • Bike: 2016 XRx
« Reply #7 on: September 22, 2021, 12:28:58 PM »
+1 on ROX
Al
Offline jfmcclure
  • Bike: Tiger800xrx
« Reply #8 on: September 23, 2021, 02:38:12 AM »
I am also a big fan of the Rox Risers
Offline Half-Click-Up
  • Bike: 2014 Tiger 800A
« Reply #9 on: September 23, 2021, 05:26:31 PM »
Out of curiosity, have any of you installed the SWMotech risers on the 800?
2014 Triumph Tiger 800A
2009 Yamaha FZ6R
Texas, USA
youtube.com/halfclickup
