Author [NL] [FR] [ES] [DE] [SE] [IT] Evotech sat nav bracket problem  (Read 2711 times)
  • Offline crispey   gb
    • Tiger Pro  ‐    140
    Offline crispey
    • Bike/Model: tiger 900,
    • Country: gb
    on: Jun 01, 2023, 09.46 am
    Ok, I received my evotech sat nav mount for my gt pro and started fitting it, Iíve got to the point where Iím mounting the main bracket, Iíll be b%gg#rd if I can get the 2 35mm bolts to take, Kat night Iíd been trying for 2.5 hours off and on and had no luck, this morning Iíve spent 1/2 hour and got no closer, how do you know when the holes are lined up, more importantly how do you line them up??
    TIA
    • Tiger Pro  ‐    140
    • #1
    Offline crispey
    • Country: gb
    Re: Evotech sat nav bracket problem
    Reply #1 on: Jun 01, 2023, 02.04 pm
    Ok, solved it, there seemed a lot more forcing of things against themselves, once I got past the fact that I might thread a couple of screws or crack the screen I managed it. Brawn before brain :164:
  • Offline l41w
    • Tiger Cub  ‐    2
      #2
    Offline l41w
    Reply #2 on: Jun 02, 2023, 08.37 pm
    Mine was the same, absolute pain in the arse and makes me wonder if the price is worth it. Vibrated like a shitting dog when I have a 595lm mounted on it, its a lot better now I have a Garmin XT as its lighter
  • Offline Chippy4467   gb
    • Tiger Pro  ‐    144
      #3
    Offline Chippy4467
    • Bike/Model: Tiger 800 XRT
    • Country: gb
    Reply #3 on: Jun 03, 2023, 06.29 pm
    *Originally Posted by l41w [+]
    Had the same vibration problem with Evotech bracket on my 800 XRT - only kept it on for about 400miles as don't want to knacker my GPS unit.   :005:    Now using the Triumph one on bars as a temp measure - far from ideal but better than dead Sat Nav.  Think I have a design solution for the 800 but it means cutting slots in the plastics under the screen to get to a solid mounting point.  I've checked and replacement plastic bits are far cheaper than a new GPS (if necessary when I eventually sell it).
  • Offline mcinlb   scotland
    • Tiger Master  ‐    609
      #4
    Offline mcinlb
    • Bike/Model: 2020 Tiger 900GT
    • Country: scotland
    Reply #4 on: Jun 04, 2023, 06.15 pm
    I use the Evotech sat nav mounting and there was some vibration on the nav unit, just stuck a block of hi-density foam between the nav unit and bar / screen.. solved.
    • Tiger Pro  ‐    144
      #5
    Offline Chippy4467
    • Country: gb
    Reply #5 on: Jun 04, 2023, 10.17 pm
    With my 800 the screen was vibrating as well, to point that it would lower itself on its own - cured that by adding an extra washer in the top spring arrangement but it still jumped around too much for me
  • Offline TT800XRT   us
    • Tiger Cub  ‐    7
      #6
    Offline TT800XRT
    • Bike/Model: 2018 Tiger 800 XRt
    • Country: us
    Reply #6 on: Nov 20, 2023, 08.37 pm
    I recently mounted the Evotech GPS mount for my TomTom on my 2018 800XRT.  It fits beautifully, but every time I hit a bump or a pothole my windshield goes lowers.  Has anyone else had this problem and did you solve it?
    • Tiger Pro  ‐    144
      #7
    Offline Chippy4467
    • Country: gb
    Reply #7 on: Nov 20, 2023, 09.34 pm
    Yes and more worrying was the way the sat nav (mines a Garmin 660) was bouncing around
    Tbh the bracket isnít fit for purpose because of the way it mounts on the bike
    To solve the screen moving down I fitted a very thin washer behind the spring on both of the top screen slide mounts.
    I nearly returned the bracket but I already had a Triumph mount as well ( mounts to handlebars) so I cut the Evotech down and fitted part of the Triumph mount to it to reduce the ďoverhang/cantileverĒ and therefore the bouncing
    Works ok now - will try and post a pic tomorrow
    • Tiger Cub  ‐    7
      #8
    Offline TT800XRT
    • Country: us
    Reply #8 on: Nov 20, 2023, 10.02 pm
    Thanks.  I don't have vibration issues.  But the screen lowering is a pita.  I'd love to see the pics.
    • Tiger Pro  ‐    144
      #9
    Offline Chippy4467
    • Country: gb
    Reply #9 on: Nov 21, 2023, 08.27 pm
    Hopefully uploaded pics. Sorry they are not too clear as not in a position to remove the screen atm (and I have a locking device fitted to secure the Garmin in the mount that makes it more confused).  As I said I cut the Evotech short  then I cut a block of Aluminium to fit the bracket on the Triumph mount and bolted it to the Evotech.  Hope that makes sense.
