Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: 2 year fluid change  (Read 2020 times)
2 year fluid change
« on: April 30, 2013, 12:50:17 PM »
Points of note.
1.  The brake fluid is easy.  Did find that the front reservoir screws were barely finger tight.  Used my trusty bit driver which fitted perfectly.
2.  Coolant change.  The Triumph instructions are spot on.  I flushed my system after draining, then filled slowly, stopping frequently to squeeze the hoses to release air.  Didn't have an assistant, except Paws, who just looked at me then curled up in the sun.  Dogs hur!!  So tilting the bike all the way over involved bracing against a wall and getting the hip in and low.  Helps to get air out.  All in about an hour to change then a good clean and lubrication session prior to re-assembly.
Will get a replacement radiator bleed plug as a spare.  Unless very careful it is easy to chew the cross head slots.
Tools:
A funnel, with a long spout, or a short spout and some tubing.
Offline grin factor
  • Bike: Blue Tiger 800
Re: 2 year fluid change
« Reply #1 on: April 30, 2013, 08:36:53 PM »
Did you find any difference changing the brake fluid? I changed mine after 3 yrs and it was just the same, as on other bikes too.
The less you give a hoot, the happier you'll be.
« Reply #2 on: April 30, 2013, 08:39:13 PM »
*Originally Posted by grin factor [+]
Looked exactly the same.  Although that's not to say it hasn't absorbed water, or just plain degraded.  Having said that the brakes were working fine prior to the change.
Offline markbvt
  • Bike: Bonnie/T800XC
« Reply #3 on: May 02, 2013, 02:35:17 PM »
Good to know about the coolant change. Out of curiosity, do you have one of the early models with the bleed screw in the top radiator hose, or one of the later ones with a plain hose?
--mark
« Reply #4 on: May 02, 2013, 02:57:55 PM »
*Originally Posted by markbvt [+]
--mark
Rarest of the rare - Venom Yellow Silver Framed WITH the brass bleed screw
Offline Not_Found
  • Bike: 2011 Roadie
« Reply #5 on: January 13, 2021, 12:24:46 AM »
Me too!
Offline Grumps
  • Bike: 2018 800 Xca
« Reply #6 on: January 13, 2021, 08:43:28 AM »
Well done. Resurrected a thread nearly eight years old. Wonder if that is a record :002: :002: :002:
« Reply #7 on: January 13, 2021, 04:27:20 PM »
Could be but at least someone is reading the older threads. Still have same tiger.
Offline Not_Found
  • Bike: 2011 Roadie
« Reply #8 on: January 13, 2021, 06:25:32 PM »
Yeah, I knew it was an old thread but I'm doing a lockdown service an my bike at present and saw "Venom Yellow Silver Framed WITH the brass bleed screw" while browsing coolant change wisdom.   I never realised the old girl was so rare   :046:
Offline Londonglide
  • Bike: xc
« Reply #9 on: January 13, 2021, 06:59:57 PM »
My 2012 800XC in Orange has the bleed screw....
